10 years agoPLL and IO Setup/Hold
Hi, After compilation I am getting warning ID: 176441 which states: The I/O pin <name> cannot meet the timing constraints due to conflicting requirements. The I/O pin is a PLL compensated I/O, ...
10 years ago --- Quote Start --- not sure exactly but my suspicion is that your requirement asks for clock skew while your pll mode is in normal compensating mode which deskews clock. --- Quote End --- That seems exactly right. Our design has an sdc file which specifies a max/min skew requirement.
