13 years ago
Please send me in the correct direction.
I have a 4 bit vector as an input, i must split this into two 2 bit vectors (symbols) .For each symbol I need to send to the output the 8 values which are stored in arrays. I am new to VHDL so any advice on improvement to my code is welcomed.
This is what I have done so far
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity mod2 is
Port ( data_in : in STD_LOGIC_VECTOR (3 downto 0);
reset : in STD_LOGIC;
clock2 : in STD_LOGIC;
data_out : out STD_LOGIC_VECTOR (7 downto 0));
end mod2;
architecture Behavioral of mod2 is
signal symbol : std_logic_vector (1 downto 0);
--signal symbol2 : std_logic_vector (1 downto 0);
signal a : integer range 0 to 7 :=0;
signal b : integer range 0 to 7 :=0;
signal c : integer range 0 to 7 :=0;
signal d : integer range 0 to 7 :=0;
signal count : integer range 0 to 16 :=0;
signal data_out_a : integer range -128 to 127;
signal data_out_b : integer range -128 to 127;
signal data_out_c : integer range -128 to 127;
signal data_out_d : integer range -128 to 127;
type a_array is array (0 to 7) of integer range -128 to 127; -- symbol 00
signal a_look_up : a_array := (0, 32, 64, 32, 0, -32, -64, -32);
type b_array is array (0 to 7) of integer range -128 to 127; -- symbo1 01
signal b_look_up : b_array := (0, 64, 127, 64, 0, -64, -128, -64);
type c_array is array (0 to 7) of integer range -128 to 127; -- symbol 10
signal c_look_up : c_array := (0, -32, -64, -32, 0, 32, 64, 32);
type d_array is array (0 to 7) of integer range -128 to 127; -- symbol 11
signal d_look_up : d_array := (0, -64, -128, -64, 0, 64, 127, 64);
begin
process(clock2, reset)
begin
if reset = '1' then
count <= 0; --set counter
elsif clock2='1' and clock2'event then
if count <= 15 then -- check for max value
count <= count + 1; --increment
else
count <= 0; -- roll over
if count < 8 then symbol <= data_in(3 downto 2);
else symbol <= data_in(3 downto 2);
end if;
end if;
end if;
--end process;
case symbol is
when "00" => data_out <= std_logic_vector (to_signed(data_out_a, 8));
data_out_a <= a_look_up(a);a <= a + 1;
when"01" => data_out <= std_logic_vector (to_signed(data_out_b, 8));
data_out_b <= b_look_up(b);b <= b + 1;
when"10" => data_out <= std_logic_vector (to_signed(data_out_c, 8));
data_out_c <= c_look_up(c);c <= c + 1;
when"11" => data_out <= std_logic_vector (to_signed(data_out_d, 8));
data_out_d <= d_look_up(d);d <= d + 1;
when others => null;
end case;
end process;
end Behavioral;
    A few problems here.
    First of all, the case statement in the process is not inside the clocked part of the process. This is bad practice, as if you really meant it to be asynchronous logic, it should be in it's own separate process. The fallout is you have many signals missing from the process sensitivity list.
    The way the code is, you are creating many latches - for data_out_a/b/c/d and the signals a b c d. I highly suggest you separate these processes first or put this code inside the clocked part of the process.
    Thanks for your advice, I am still struggling with this though.
    Is sensitivity list what goes in the parenthesis after process?
    I do want this to be synchronous
    yes, thats the sensitivity list.
    If you want the case statement to be synchronous, put it inside the if rising_edge(clk) part of the code.
