15 years agoHi, kaz:
Thank you for pointing out the problem. According the ADC's datasheet, the maximum tCO is 9 ns with respect to ADC_CLK falling edge(ADC_CLK is the sample clock of ADC). The minimum tH(Output hold time from COUT to data invalid) is 2 ns, and the minimum tSU(Output hold time from COUT or COUT to data invalid) is 8 ns, both with respect to COUT rising edge(COUT is the latch clock for ADC's data outputs). The datasheet recommends "Data out should be referenced to COUT", while it also says "The relationship between ADC_CLK and COUT is not fixed and depends on the power-on conditions". From the recommendation of ADC datasheet, I think the relationship between COUT and tCO is not fixed. In other words, tCO varies in different power-on conditions. So tCO may be useless for the input delay constraints. That's why I refered to setup and hold timing of ADC output in my thread. Now I have no idea how to constrain my design. Can you give me some enlightment? Thanks in advance!
