EvanR
4 years agoPlatform Designer problem WSL
Hello, I'm trying to migrate an old project, quartus II/15, to the latest quartus standard edition:
Quartus 21.1.0 Build 842
Patches Installed: 0.01std
Previously the project was run and built...
AhmadSaleh
3 years agoHi,
First, make sure you do all the steps related to the WSL indicated here.
In my case, the problem is due to the WSL default distribution. It should be set on Ubuntu-18.04.
You can list the WSL distributions and check the default using this command:
wsl --list
Also, you can set Ubuntu-18.04 as the default distribution using the following command:
wsl -s Ubuntu-18.04
