Aswinkrishnan
3 years agoPlatform designer Avalon Communication
Hi
I am trying to generate a simple system which consists of an Avalon MM master BFM and an Avalon memory mapped slave. My avalon slave consists of two components, having an interface to the other ...
sstrell
3 years agoAgain it's still not clear what you are referring to. Did you use the Component Editor to create a custom component and you are saying that when you add the component to a system, you are not seeing the interfaces you defined? Maybe screenshots or more detail needed.
