RWitt
7 years agoPlatform Designer - A10 PCIe SR-IOV Won't run at 8Gbps when SR-IOV is enabled.
Same core with SR-IOV disabled runs fine at the 8Gbps Gen3 speed. When SR-IOV is enabled (1 PF, no VFs, MSI-X enabled) we enumerate at 5Gbps - maximum. And the lspci-configuration-space status for Li...
Nathan_R_Intel
Contributor
7 years agoHie,
I tested using Quartus Prime Pro v18.1. If "enable SR_IOV support" is enabled, the system messages releases an error if 1 PF is selected and no VF is used.
Could you check if assigning at least 1 VF allows the link to achieve PCIe Gen3x8.
I am suspecting the equalization registers (to enabled equalization adaptation for Gen3 Rx) require at least 1 VF for the registers to be present in the PF.
Nathan
