Platform Designer - A10 PCIe SR-IOV enables AER in the config-space even though it has not been enabled in PD.
When you enable SR_IOV, the ARI support is enabled thus enabling AER capability (although not selected in the IP GUI).
Please check my reply for the following question:
Question:
Also, and discussed on another post, I see in documentation an implication that with SR-IOV enabled the AER capability is always in the config space (I have not checked whether or not the "Enable Advanced Error Reporting" configuration (on/off) affects whether it indicates enabled (supported) or not. Is this observation true?
Answer:
I cannot confirm if your observation is true as I never tried reading back AER errors with SR-IOV by unchecking "Enabled Advanced Error Reporting"
Since ARI is enabled with SR-IOV enabled, the AER Enhanced Capability Registers are available to indicate AER is available. However, to ensure the Configuration Space Registers are available please "Enable Advanced Error reporting".
Nathan
