Platform Designer - A10 PCIe core - with SR-IOV not enabled and MSI-X enabled I can't export the msix signals.
Hie,
Now i understand your problem better. When you select interface type "Avalon ST" you are not able to see the MSI-x signals but when select Avalon St with SR-IOV you are able to see them.
Its because the Avalon-ST interface enables MSI-X interrupts differently then Avalon-ST interface with SR-IOV whereby the conduits or MSIx interrupt signals are only offered in the Avalon-ST interface with SR-IOV only.
This is covered in our documentation. If you only intend to use Avalon-ST, then you may refer to Implementing MSI-X Interrupts in our user guide.
For Avalon-ST interface, please refer to the following user guide:
(https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avst.pdf)
For Avalon-ST with SIOV interface, please refer to the following user guide:
(https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_sriov.pdf)
Nathan
