RWitt
7 years agoPlatform Designer - A10 PCIe core - with SR-IOV not enabled and MSI-X enabled I can't export the msix signals.
(SR-IOV is "not" enabled) When I enable MSI-X support I can't get the conduit for those signals to show up in Platform Designer, only the MSI signals. I enabled that support but nothing is generated ...
Nathan_R_Intel
Contributor
7 years agoHie,
What do you mean by SR-IOV hardcore. Could you provide a snapshot of the IP you are referring to as SR-IOV hardcore, SR-IOV "not enabled". I am looking into this case but have difficulties to understand the terms used. Hence, it will be useful if you could provide the snapshots of the IP so I could understand better and provide an explanation or guideline.
Nathan
