Platform Design tool gets error when generating system: Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga_lite/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt"
Seems like we have patch for this https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2020/fatal--cannot-generate-ip-in-a-windows-evironment-.html.
The error message reported are similar,
ERROR: Found Error => border: 2019.06.13.20:07:57 Info: p0: "hps_sdram" instantiated altera_mem_if_ddr3_hard_phy_core "p0"
ERROR: Found Error => border: 2019.06.13.20:07:57 Error: seq: Cannot locate the Nios II Command Shell. Nios II SBT must be installed to generate UniPHY IP cores.
ERROR: Found Error => border: 2019.06.13.20:07:57 Error: seq: An error occurred
ERROR: Found Error => border: while executing
ERROR: Found Error => border: "error "An error occurred""
ERROR: Found Error => border: (procedure "_error" line 8)
ERROR: Found Error => border: invoked from within
ERROR: Found Error => border: "_error "Cannot locate the Nios II Command Shell. Nios II SBT must be installed to generate UniPHY IP cores.""
Can you try this patch and let us know the result?
Patch link is broken. Could you post a new link? Thanks. I'm running into the same error as others on this page.
