Pack_of_lone_wolves
2 years agoPlacement constraints for PLL in QPP
There is the feature called as logic lock which can fix placement of a node, I want to know if it is possible to use logic lock for fixing position of PLL? I get a warning in plan stage of fitter as "...
- 2 years ago
You can choose "Location" for that version of Quartus Prime.
AqidAyman_Altera
2 years agoFrom my opinion, logic lock will reduce the flexibility for you on the timing side of the design. My suggestion is you need to change the PLL location through the qsf assignments.
- Pack_of_lone_wolves2 years ago
Will try this and let you know. - Pack_of_lone_wolves2 years ago
I could see following cmd in qsf file:
set_instance_assignment -name RESERVE_REGION "coordinates" -to PLL_instance.
set_instance_assignment -name RESERVE_PLACE_REGION OFF -to PLL_instance
For the second cmd, I changed it to ON and reran the Fit - Plan, but still same message is displayed. - Pack_of_lone_wolves2 years ago
If I refer QPP settings file reference manual, what type of settings should be used to ensure desired PLL placement?
