13 years ago --- Quote Start --- but you shift statement is from msb to lsb i.e. bit3 starts as zero then bit2 then bit1 then bit0. So bit 3 will always be zero --- Quote End --- you also need to load qlatch with input first at load then start the shift. You are just assigning input 3 bits to qlatch
