dmanikanth
3 years agoPipelining output data of RAM (M20K) through Quartus tcl console
Hi
I want to pipeline output data of M20K RAM block as few M20K --> M20K paths which are not meeting timing by around 2ns. I have tried ECC pipelining but getting error that the RAM should be of 5...
RichardT_altera
3 years agoWhich RAM IP that you are using in your platform designer? Perhaps you can share a simple project .qar file so I can understand better.
Some ways that I can think of is to add register at the RAM block output and change the project setting so that Quartus is allowed to RAM retiming. (change this in the Fitter Advanced setting)
You may try to change the Optimization Mode to "High Performance Effort".
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
