Pipeline parameter issues for LPM_Divide
Hi FvM,
thanks for your replay and the Infos. I'm testing my design on the Cyclone IV FPGA first for other FPGA so i think you're right about expecting too much form it.
I have to use set_mulicycle_path for the outputs otherwise i'll have setup and hold violations. Is there something else i can do there ?
- set_multicycle_path -setup -end -from [get_registers {wr_fifo:DUT10|q_wurzel_s*}] -to [get_ports {q*}] 2
- set_multicycle_path -hold -end -from [get_registers {wr_fifo:DUT10|q_wurzel_s*}] -to [get_ports {q*}] 1
I tried yesterday what the report timing closure recommendations in Timing Analyzer and it showed me this:
- turn off auto shift register replacement in Analysis & synthesis settings.
- turn on physical synthesis for combinational logic in fitter Setting.
Surprisingly it worked and now im having f_max in worst-case up to 257.4 MHz.
Is it right to change the setting like that or what ?
thanks in advance
it's not obvious to me that multicycle applies to the divider. It presumes that input data isn't updated every clock cycle. If so, why aren't you running the divider at a lower clock rate? To answer the question we would need to know design details.
- FPGA_Newbie1 year ago
Hi FvM,
thanks for your relpy.
Your were right about the lpm_divide speed, i tried the PLL with 4 different outputs-Freqence (100MHz, 150MHz, 200MHz and 300MHz) and im getting these timing errors for lpm_divide only when im using the 300MHz clock, max frequency it can do 220MHz with these same parameters.
But now im getting removal timing errors, i didn't get this before and don't know why im getting these now
Please refer to the .zip file for its contents:
- RTL Viewer
- Timing summary
- Removal 'reset' report
- .sdc file
PS: i got this now. it should be contacted (assignment) to the 'reset' pin hardware.
please take a look in zip-file.
thanks in advance
