Pipeline parameter issues for LPM_Divide
I performed test compilation of lpm_divide with given parameters and found that it can't achieve higer clock speed than about 190 MHz on Cyclone IV, speed class 6 with maximal lpm_pipeline, despite of huge resource usage. For comparison, a sequential divider, e.g. divider.v contained in stx_cookbook11/arithmetic (see GitHub - thomasrussellmurphy/stx_cookbook: Altera Advanced Synthesis Cookbook 11.0) achieves 170 MHz with less than 1/5 of lpm_divide logic resources.
Means, you are expecting too much from Cyclone IV. Need to run the respective logic with lower clock speed. Recent low cost FPGA, e.g. Cyclone 10 LP achieves similar performance.
What's your ADC sampling rate? If it's really that high (250 MHz), consider an alternative RMS topology that doesn't need continuous full speed division.
