10 years agopins - component
Hello. Can I physically (pin FPGA) use ports operator, which is used as an ingredient? When I use the pin planner, I see ports only main entity. How to do it? Thanks.
10 years agoYou can assign the pins to the port names on the top level entity. You dont need to call your top level ports the same as the pin names.
