10 years agopins - component
Hello. Can I physically (pin FPGA) use ports operator, which is used as an ingredient? When I use the pin planner, I see ports only main entity. How to do it? Thanks.
10 years ago --- Quote Start --- you can name pins the same as the ports on the top level entity. busses need to be connected by individual bits. --- Quote End --- So, the physical pins must be declared in the main entity?
