Pin out report with Function column
How can I get Pin report table that include information of Pin Function for each Pin Number
in the batch mode or by tcl comand in the Quartus
Example:
|Pin Number|Special Function|IO Bank|
| T1| DIFFIO_RX_B3p,DIFFOUT_B3p, DQS1B, DATA12|3A|
|M1|DIFFIO_TX_B4n, DIFFOUT_B4n, DQ1B, DATA9 |3A|
- sstrell
I believe this is in the .pin file generated whenever you compile a design. You can also check out the datasheet for your targeted device family, which will point to a complete pinout document for your particular device.
#iwork4intel
- Vicky1
In addition to the above post, you can refer the links below for pin-out Files for Intel FPGA Devices,
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
https://www.intel.com/content/www/us/en/programmable/documentation/lit-dpcg.html
Vikas
- UMosh
Hi
I haven't found the way to get the Function field in the .pin file.
Do you familiar with this option?
is there any flag to enable additional columns in the pin file?
Best Regards
- Vicky1
You can use .csv file & here you can add addition column.
Go to "Assignments" -> "Pin Planner" then right click in "All pins" window & select "Customize Columns.."
Refer the screenshot for column added as a "Pad Number"
For .csv file : In Pin Planner "File" -> "Export"
Vikas
- Vicky1
Have you resolved the issue?
should I consider to be case closed?
Vikas
- UMosh
Hi Vikas Actually I’m searching the way to get all devices data by one shot, And not download it one by one. Is it any way to do it ? May be via script? Best regards
- Vicky1
I think, It may not be available all devices data in one shot.
but for pinout report with function column, you can check my previous post.
Vikas
