UMosh
7 years agoPin out report with Function column
How can I get Pin report table that include information of Pin Function for each Pin Number in the batch mode or by tcl comand in the Quartus Example: |Pin Number|Special Function|IO Bank| | T1|...
Vicky1
7 years agoHi,
You can use .csv file & here you can add addition column.
Go to "Assignments" -> "Pin Planner" then right click in "All pins" window & select "Customize Columns.."
Refer the screenshot for column added as a "Pad Number"
For .csv file : In Pin Planner "File" -> "Export"
Vikas
