TuckerZ
3 years agoPin Assignment Import using .tcl file
I was looking into how to import pin assignments in a .tcl file into Quartus Standard Edition and section 2.3 of the Design Constraints User Guide shows the following table. The table list...
- 3 years ago
You can just copy the assignments into your .qsf file.
Nurina
3 years agoHi,
The .qsf file mainly uses tcl commands, so you should be able to import the pin assignments if you just copy the location assignments from the .tcl file into your .qsf file.
Nurina
