13 years agoPDN Tool Zh = Zs + Zv
Hello All!
The PDN Tool shows the impedance between the decoupling network and BGA on the graph as Zh = Zvia + Zspreading, but if I leave the plane and BGA vias unchanged, the Zh value changes if I select another power rail. e.g. changing from VCC to VCCIO, Zh goes up. Can anyone explain what's happening here? I imagine that Zh is also including the package internal Z value for the different rails, but a clarification on this would be useful. If that is the case, then what power rail should be used in the PDN tool when sharing several rails on one supply. The one with the lowest or highest Zh? Thanks, Ken
