Agrl
3 years agoPCIE is not getting detected
After merging the PCie x4 and X8 hard ip. PC is taking more number of reboot to detect the pcie. we are using fpga as a device, the one observation is from PC we are not getting the continous clock....
Wincent_Altera
3 years agoHi,
I check internal resource, We never encounter this issue before.
Meanwhile, can you
- Ensure power, reset, clock specifications are being met, and review how device is connected to system as per mention in the user guide.
- I would recommend that you don't drive the power_mgmt bus. I suspect this is what is causing your problems.
- If you just use our auto-generated example design, re-targeted to your hardware, does it work correctly?
- https://www.intel.ca/content/www/ca/en/support/programmable/articles/000084214.html
Wincent_Intel
