PCIE is not getting detected
Enabling the continuous clock from the PC should not directly affect the FPGA pins.
However, it is important to ensure that the FPGA is properly configured to receive the continuous clock signal from the PC.
Not sure about your device, so is possible for you to use the GX/GT device, they can support up to 4 HIPs If no ,
back to your question , there is no setting to configure the HIP to support Avalon-ST and Avalon-MM both,
but you can use the Avalon-ST and implement some logic for the control path
Regards.
Wincent_Intel
Hi Sir,
Thank you for your reply. I have 2 questions.
Q1. my PCIe Device is self powered. In any scenario. If Device is OFF and PC is ON. and PC provides the PCIe Clock continuously will there be any impact on the PCIe EP device(FPGA)? I am using arria 10 GX device .
Q2. If i check the x8 pcie and x4 pcie as a seperate code. it is working fine. I am using Avalon MM DMA method for both PCIe. If i merge the X8 and X4 pcie. PCie is not getting detected for the first two reboot of PC. What may be the issue?
Thanks in advance
