PCIe IP example error: Failed to open design unit file "../../../top_core.vo" in read mode.
I tried shortening the directory to which Quartus restores the .qar file to just "D:/c/", but I still get this error:
# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016
# Start time: 23:43:27 on Jul 30,2019
# vlog -reportprogress 300 "+incdir+../../common/testbench/+../../common/incremental_compile_module+.." -work work ../../../top_core.vo
# ** Error: (vlog-7) Failed to open design unit file "../../../top_core.vo" in read mode.
# No such file or directory. (errno = ENOENT)
# End time: 23:43:27 on Jul 30,2019, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
# ** Error: D:/intelFPGA_lite/18.1/modelsim_ase/win32aloem/vlog failed.
# Error in macro ./runtb.do line 115
# D:/intelFPGA_lite/18.1/modelsim_ase/win32aloem/vlog failed.
# while executing
# "vlog +incdir+../../common/testbench/+../../common/incremental_compile_module+.. -work work $vfile"
# ("while" body line 2)
# invoked from within
# "while {[gets $simlist vfile] >= 0} {
# vlog +incdir+../../common/testbench/+../../common/incremental_compile_module+.. -work work $vfile
# ("eval" body line 3)
# "_comp"
anything else i can try? can you send me the correct top_core.vo file directly?
Yes, I have able to replicate the scenario attached modelsim error log.
Let me check and come back.
Anand
- MMorr237 years ago
Any update?
- AnandRaj_S_Intel7 years ago
Still working on it.
we will update you soon.
Sorry for the inconvenience caused.
Hi, is there any update? Please help
Sorry for the inconvenience caused, Still working on it.
Meanwhile kindly check below links which have similar issue.
Anand
