xiaoxu
5 years agoPCIe ip核,点击"generate example design"生成的tcl使用时报错;
您好,
在使用quartus prime 20.3版本生成ip核时,遇到以下两个问题:
1)勾选上“simulation”之后,ip核生成不成功;
2)使用ip核配置界面上的“generate example design”,只会生成一个tcl文件,用该tcl在tcl console界面运行时,tcl的第一行就会报错“Error:"package require -exact qsys 19.1"”。
- Rahul_S_Intel1
Hi ,
Kindly sent the generated example design for my review. So that I can recreate the issue in house, if the issue is valid, I will try to provide solution.
In my point of view, the generated example design should work.
