8 years agoPCIe FPGA and Thunderbolt to PCIe interfaces
Hi, Did anyone try using a pcie fpga board over thunderbolt? I am trying to run some OpenCL code, but "aocl diagnose" doesn't seem to work. Fails trying to communicate over the PCIe bus. Dri...
8 years ago --- Quote Start --- I flashed the it using the following command based on the installation guide: flash_recovery.bat base.aocx which uses the JTAG instead. Documentation states that if "aocl flash acl0 base.aocx" has issues, you can flash using that command instead and that worked. --- Quote End --- This is the correct method. Device manager also seems to indicate that your device is working correctly. I have never used Windows for this purpose, maybe there is some Windows-specific step here that I am missing. --- Quote Start --- The next logical thing to do is to try it on a desktop PCIe slot once I get the license key from Nallatech. The BSP is linked to each individual machine, unfortunately and this laptop setting was mainly for me testing out the setup. Its a university board that I am using on loan to work on a project. I still got a few other Nallatech boards that needs to be installed... --- Quote End --- You need a license only for installation of the BSP. When it is installed, it can be copied to any other machine and it will work just fine. You can just copy the installed BSP from your laptop to any other machine you have.
