8 years agoPCIe FPGA and Thunderbolt to PCIe interfaces
Hi, Did anyone try using a pcie fpga board over thunderbolt? I am trying to run some OpenCL code, but "aocl diagnose" doesn't seem to work. Fails trying to communicate over the PCIe bus. Dri...
8 years agoI see these many "MMD ERROR: failed to scan for the PCI device." on bad WinDriver with ended license.
On last picture, please open node "Jungo Connectivity" -- for what device it present ? If no kit is inserted, this node is present ? And reload first picture for us, this is bad. Don`t use "aocl flash" and "flash_recovery.bat" until "aocl diagnose" is failed. You may only load base .sof with BSP to FPGA through Quartus Programmer and refresh device configuration in Device Manager, may be Reboot is need, then try "aocl diagnose".
