8 years agoPCIe FPGA and Thunderbolt to PCIe interfaces
Hi, Did anyone try using a pcie fpga board over thunderbolt? I am trying to run some OpenCL code, but "aocl diagnose" doesn't seem to work. Fails trying to communicate over the PCIe bus. Dri...
8 years agoDevice Manager indicates that the board is active:
https://alteraforum.com/forum/attachment.php?attachmentid=14896&stc=1 I flashed the it using the following command based on the installation guide: flash_recovery.bat base.aocx which uses the JTAG instead. Documentation states that if "aocl flash acl0 base.aocx" has issues, you can flash using that command instead and that worked. Running "aocl diagnose acl0" produces the following: D:\intelFPGA\17.1\hld>aocl diagnose acl0 Verified that the kernel mode driver is installed on the host machine. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. Using platform: Altera SDK for OpenCL Failed clGetDeviceIDs. Error code: -1 Verified that the kernel mode driver is installed on the host machine. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. MMD ERROR: failed to scan for the PCI device. Using platform: Altera SDK for OpenCL Failed clGetDeviceIDs. Error code: -1 D:\intelFPGA\17.1\hld> The next logical thing to do is to try it on a desktop PCIe slot once I get the license key from Nallatech. The BSP is linked to each individual machine, unfortunately and this laptop setting was mainly for me testing out the setup. Its a university board that I am using on loan to work on a project. I still got a few other Nallatech boards that needs to be installed...
