10 years agoPCIE DMA stratixV simulation with modelsim 10.4c
Hello, I can generate the simulation of the example design as described in "V-series Avalon-MM DMA interface for PCIe solutions.pdf". I would like to understand the whole design including the test...
10 years agoJust wonder if there is any detailed description on the design example in the user guide? If yes, you can start from there. Then run through Modelsim to look into the behavior of the design.
