14 years agoPCIe BFM
So Altera have decided to stop shipping the PCI BFM with their IP, meaning their simulation demos are now a bit useless: # ** Failure: SUCCESS: BFM model not available! So the reply from mys...
14 years agoTricky,
When you generate the PCIe core using MegaWizard, all the testbench files including the BFM are also generated. For example, if you generate a core called "pcie_core", then the BFM will be in the location similar to. ..\pcie_core\pcie_core_examples\chaining_dma Have you tried that? --- Quote Start --- So Altera have decided to stop shipping the PCI BFM with their IP, meaning their simulation demos are now a bit useless: # ** Failure: SUCCESS: BFM model not available! So the reply from mysupport was: "the error that you are seeing is not because you have done anything wrong, or that you are using vhdl rather than verilog as your simulation environment. unfortunately i have been instructed to report that due to business concerns, altera is not currently shipping a pci express bus functional model in the current version of the tools. i'm afraid that there is not anything that i am able to do to assist you in generating a pci express bfm for this version. in order to simulate interactivity with the pci express core, you will need to source a pci express bus functional model to plug into the testbench." So does anyone know where I can get a PCI BFM model from that will work with this demo, or what was the last version of Quartus to ship with the BFMs? --- Quote End ---
