13 years agoPCI-E hard IP in Qsys, external Interrupt connection
Hi All,
I am new to qsys tool.... I need to implement a system in Qsys using PCI-E bus. System consist of PCI-E bus, 6 UART cores and other custom logics inside Altera FPGA interfacing with external host.PCI-E configured as End point only. In Qsys I have added PCI hard IP, Avlon MM-slave translator, Clk component, Reset component and an Irq bridge. There are 6 interrupts coming from 6 UARTs need to be passed to host through PCI-E using MSI mode. I am using UARTs from external vendors(not qsys components). How these interrupt need to be connected to PCI-E? whether IRQ bridge is required? How I can connect UARTs interrupt to IRQ bridge? How many IRQ bridges is required? Thanks in advance.. zeal
