13 years ago --- Quote Start --- Yes i ment "not available". What a pity! Mayby You have, or anybody else a modelsim project created for VHDL? --- Quote End --- The problem is that Altera does not supply the required IP in VHDL format. If you want to use Modelsim-ASE and want to use Altera IP that is in Verilog or SystemVerilog, then you need to write your code in SystemVerilog too. Cheers, Dave
