13 years agoThe lack of the PCIe BFM is one of the reasons I suggested you create a testbench for the Avalon-MM components, i.e., create a testbench at the Avalon-MM level using the Verification IP Suite.
Read this tutorial: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial I haven't checked 12.1 for the PCIe BFM, however, the BFM in whatever version I tested in this thread http://www.alteraforum.com/forum/showthread.php?t=35678 was in Altera's own words designed as a read-only BFM, i.e., you can only use their code, not actually edit it and do anything useful. Cheers, Dave
