13 years agoYour ideas sound fine to me. Why not just go ahead and implement them?
I looked at the Altera PCIe core and wrote up some notes: http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_pcie_analysis.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_pcie.zip I wasn't particularly impressed with the Qsys component. It should really have a DMA bridge as part of the component. For your design, I'd generally use two clocks; PCIe clock and FPGA clock. I'd then use a dual-clock FIFO to cross clock domains. This allows you to have the data processing clock (the FPGA clock) faster than the PCIe clock (if you want). Cheers, Dave
