10 years agoPassing array as a port via hw.tcl file
Hello, System Verilog supports using array as a port. We are creating our own component which uses System Verilog. That component is going to be used in Qsys. So, we will need to use hw.tcl fil...
10 years agoHello,
Thank you for your reply. Yes, we can use the method which you have mentioned. Cheers, Bhaumik
