11 years agoParameterized verilog module instance name in verilog or system verilog
Hi, I am trying create verilog module that can support parameterized instance name. I understand that the signal width and other such things can be parameterized. But can we also parameterize...
11 years agoYour explanation needs a little more work. The name of the Verilog module to your C++ code is completely immaterial. Assuming the FIFO is memory mapped, then all the C++ code needs is the address of the FIFO that it needs to read from. The C++ code does not care what the component name used in the HDL is. Sure, if you are writing the C++ to use an address map generated by Qsys, you need to look-up the name used in the Qsys system, but that name is specified in the Qsys GUI, not in the HDL implementation.
If you want to create a component that C++ code can identify, then you need a set of status registers that the C++ code can read from, eg., IP version, and HDL generics, such as the FIFO bit-width. The C++ code would read those registers first, and then go and read from the FIFO. Perhaps I misunderstand though .... :) Cheers, Dave
