13 years agoParallel compilation removed (again) from Quartus II v13.1 Web Edition
So it seems that parallel compilation, which was recently added back to Quartus II Web Edition, has been removed again from v13.1. My question to Altera is, is there any sensible reason to force y...
12 years agoDo you see a big speed improvement when using parallel compiling? On my quadcore, I see that the CPU is most of the time at 25% usage, even with parallel compilation enabled (on 11.1 SP2). What is most surprising is that even for tasks that should be very easily multithreaded, such as synthesis, Quartus doesn't seem to use more than one core. I only see the CPU go up to 100% occasionally during fitting, end eve there only for a few seconds each time. To me it doesn't seem that Altera's implementation of multithreading is that optimal. Maybe it has improved since 11.1
Fro a marketing point of view, the web edition is supposed to be used for smaller designs (it doesn't support the bigger Stratix FPGAs) so it could make sense not to have parallel compilation enabled. But I agree it's a rather low move ;) hussainw, what kind of design do you have that takes days to compile? Isn't there anything that you can optimize in there to reduce compile time? Which part takes most time?
