10 years agopackages for synthesis
Using Quartus 15.1
I am trying to define my own types for IO in my modules. I have generated the package foo_pkg.sv as follows: package FOO_BUSSES; typedef struct packed{ logic rd_wrn; logic [31:0] address; logic [10:0] burstsize; logic transaction_dv; logic dout_dv; logic [63:0] dout; logic din_dv; logic [63:0] din; logic transaction_rd; logic din_rd; } foo64_intf_p ; endpackage // FOO_BUSSES Now that I have the package defined I want to call it into the module foo_top.sv module foo_top import FOO_BUSSES::*; # (parameter A = 1, parameter B = 2) ( input CLK, input RST, foo64_intf_p FOODEF ); .... endmodule When I synthesize I get the following error Error (10161): Verilog HDL error at foo_top.sv(nn): object "foo64_intf_p" is not declared in my qip that calls these mods: set_global_assignment -library "foo_flex" -name SYSTEMVERILOG_FILE [file join "../../ip_foo/foo_common/rtl/foo_pkg.sv"] set_global_assignment -library "foo_flex" -name SYSTEMVERILOG_FILE [file join $::quartus(qip_path) "foo_top.sv"] this code will simulate using various modelsim simulators. any and all help will be appreciated.1 Reply
Could you try by using 'input' keyword before 'foo64_intf_p FOODEF'? Regards, Bhaumik
