9 years agooutput doesn't toggle when simulating with other entities in Modelsim
Hi, I'm working on a vhdl testbench to simulate the behaviour of an I2C bus. I started with an original code (written in verilog) that works, made some changes to it an simulate it's behaviour as a s...
9 years agoHere it is, I commented the two portions of the code where I'm seeing the issue:
state <= 8'h07; // signal
sda_o_e <= 1'b0; // other_signal
and
sda_o_e <= 1'b1; // signal
state <= 8'h81; // other_signal
assign at the bottom:
assign hps_sda_o_e = state; // change from assign hps_sda_o_e = sda_o_e;
