9 years agooutput doesn't toggle when simulating with other entities in Modelsim
Hi, I'm working on a vhdl testbench to simulate the behaviour of an I2C bus. I started with an original code (written in verilog) that works, made some changes to it an simulate it's behaviour as a s...
9 years agoHi, here is the code that works fine by it self:
if (condition_1) begin
signal <= '1';
end
if (condition_2) begin
signal <= '0';
end
assign output <= signal;
The conditions are met both when simulating as a stand alone unit and embedded, the problem is, when embedded on a test bench, even though the conditions are met, the output doesn't toggle, this fix made it work:
signal <= '1';
other_signal <= '1';
end
signal <= '0';
other_signal <= '0';
end
assign output <= other_signal;
