9 years agooutput doesn't toggle when simulating with other entities in Modelsim
Hi, I'm working on a vhdl testbench to simulate the behaviour of an I2C bus. I started with an original code (written in verilog) that works, made some changes to it an simulate it's behaviour as a s...
9 years ago --- Quote Start --- Hi, sorry I didn't make myself clear the first time I posted (by the way, I don't see the content of my post, just the title), the problem is that just a single output from a stand alone working module stops toggling when added to a test bench, and the fix is to assign that output to another signal at the same time that is supposed to --- Quote End --- Sorry, it was moderated - I cleared it (I could see the text, hence my reply) Again, not sure what you mean by " assign that output to another signal at the same time that is supposed to toggle". You should just assign it to a signal and then monitor the signal on a wave window. It might be easier if you posted the actual code and then specify exactly what isnt happening that you expect. That way, we can see the same problems ourselves.
