Out of memory in module quartus_syn.exe
I have tried using in multiple system to complete a Verilog code using Quartus pro software it keeps giving error Out of memory in module quartus_syn.exe (129324 megabytes used). error while compiling the code.
I have i7 6th gen processor
1tb hard disk
32gb ram
4gb graphics card.
Need help ASAP.
yoga
- BrusC_Intel
Hello, yoga.
Thank you for posting on the Intel Community Support forums for Intel® Optane™ Solid State Drives.
There is a dedicated section for that particular product, so I will move your thread there so it can be answered as soon as possible.
Bruce C.
Intel Customer Support Technician
- ak6dn
You need to provide a lot more info about your configuration.
What version of Quartus?
What is the target FPGA device?
What Operating System?
What are you compiling? Is it all your own verilog, or is it IP modules?
Be as specific as possible about each of these topics, then folks will be able to provide useful suggestions.
- yoga
Quartus prime pro edition 22.4 .
using 30 days trail version .
agilex all boards .
intended target board is Apollo Agilex SOM board.
Getting the same error regardless selecting Apollo board or any other board.
windows 10 , 64 bits.
own verilog modules. No ip blocks are used
- FvM
Is the device AGFx014? It should be compileable with 32 GB RAM, sure your system doesn't run other tasks with high memory demand simultaneously. Better upgrade to 64 GB. - yoga
Hi FvM,
The RAM has been upgraded to 64 GB and altered the pager size to 400GB but what is happing is it is using all the 64 GB RAM and then the compilation tacks more that 36 Hrs. and still 0 % is been seen in the synthesis progress bar .
regards
yoga
