12 years agoOrdering of Ports for exported Qsys signal conduits
Hi, I have a design with a Qsys that is slowley growing. I find that each time I export another signal conduit it gets added to the bottom of the component. This is the same for the generated V...
12 years agoIf you do your top level in HDL, you can use named association to keep the order how you want when you instantiate the component.
