12 years agoOrdering of Ports for exported Qsys signal conduits
Hi, I have a design with a Qsys that is slowley growing. I find that each time I export another signal conduit it gets added to the bottom of the component. This is the same for the generated V...
12 years agoThis is an old problem I also have. But there is no other way than the 2nd. Sorry.
But to make it somehow faster: You can double-click on an export and press [Ctrl]+[X] then [ENTER]. Now it's deleted. Then again click on the Export an press [Ctrl]+[V]. Now your Export is on the bottom of your BSF-File. Do this with every export in the order you want them to be and you're done. As a little help you shoul bring the IPs in this order first so you can just re-export the exports from top to bottom. I'm really sorry, but there is no other way. Steffen
