Sajith_K_Intel
6 years agoOption to redirect Quartus logs (Infos, warnings,errors) to a custom log file
Hello, Is there an option to redirect Quartus logs (Infos, warnings,errors) to a log file and know the progress while Quartus running in batch mode? currently, reports inside output_files are dumped...
Busy
6 years agoHello,
I don't know if you are on Windows or Unix...
Did you try redirection?
Example on linux:
(quartus_map projectname) >> hw_compilation.log 2>&1Does it answer your problem?
