Operating Quartus with a remote PC
Hi
My PC at work has Quartus Prime Pro installed, running with a node-locked license.
Is there any way I can remotely run that Quartus from home, with my personal PC?
Perhaps if I install a secondary node-locked license on the personal PC?
Thanks!
- AR_A_Intel
Hello
Welcome to INTEL forum. Based on my understanding on your note, you need to use the license on multiple computers. Yes, it is possible to generate a Temporary License. This license enables portability for the same user that needs to use the license on multiple computers.
Please note that a Companion license is only temporary for 2-weeks period of time.
Refer to link on how to generate temporary license in Self-Service Licensing Center.
- TSS3
Hi AabdRahman,
At home I'm running a private PC, and as such, it is too weak to run Quartus Prime Pro.
So unless I misunderstood you, I'm not sure a companion license could help,
as it cannot be installed on a PC uncapable of running said software.
My private PC can, however, connect from my home to my office work PC,
however the Quartus Prime Pro installed on that PC forbids any remote
operation, thus forcing me to actually do the work by physically being in the
office - this is the main problem I seek to solve.
Itay
- sstrell
You don't need a license for your local machine. Any remote access software (Teamviewer, LogMeIn, Webex, etc.) would work fine.
When you say "PC forbids any remote operation", do you mean that your work has a firewall or something else that doesn't let you connect to your work machine? I've used Quartus Pro remotely plenty of times with no issues.
- AR_A_Intel
Hi Sir
Based on your note, Quartus did not work form your working please and from home. To narrow down the issue. Can you provide information on your?
1) Quartus version use
2) Machine OS information
3) License.dat file
4) Error message screenshot
5) Screenshot of Quartus >> tools >> license setup
6) assembler report .asm.rpt file
· The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.
And for privacy, you can reply/attach your file in private message.
- TSS3
Hi AabdRahman,
My Quartus Pro works both from home, and at work.
From home, it's provided I use a simple software, such as Team-Viewer - as opposed to VPN.
IMO this SR may be closed.
BR,
Itay
- AR_A_Intel
Sounds good, hope everything is working well at your side. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
