Operating Quartus with a remote PC
Hi AabdRahman,
At home I'm running a private PC, and as such, it is too weak to run Quartus Prime Pro.
So unless I misunderstood you, I'm not sure a companion license could help,
as it cannot be installed on a PC uncapable of running said software.
My private PC can, however, connect from my home to my office work PC,
however the Quartus Prime Pro installed on that PC forbids any remote
operation, thus forcing me to actually do the work by physically being in the
office - this is the main problem I seek to solve.
Itay
You don't need a license for your local machine. Any remote access software (Teamviewer, LogMeIn, Webex, etc.) would work fine.
When you say "PC forbids any remote operation", do you mean that your work has a firewall or something else that doesn't let you connect to your work machine? I've used Quartus Pro remotely plenty of times with no issues.
- TSS35 years ago
Hi sstrell,
Quartus Prime Pro needs a license by definition, as it targets higher-end devices such as
the Arria10 I'm working on.
My place of work has a firewall yet allows remote accessing, used by contractors to remotely
participate in integration sessions in our labs, and for writing documents from home,
just to name a few examples.
I suspect the reason why you're able to remotely access this Quartus is because in your case
the Quartus's license type is FLOATING - whereas in my case, it's NODE-LOCKED.
Also, I can definitely remotely access Quartus Prime LITE, I assume the reason is,
that in the LITE case, a software exempt from licensing (as opposed to the PRO) is deemed
as a software with floating license i.e. permits remote accessing.
Pls. advise.
Itay
- sstrell5 years ago
No, I always access node-locked machines that have their own license files.
So what you're saying is that you can access the machine but you can't run Quartus, so this is a licensing issue, not a remote access issue. If it's Standard or Pro and you're not using a floating license server, then the machine you're trying to access needs its own license file that is specified in Quartus in the Tools menu (License Setup). But you say you have that.
So I guess clarification is needed on this: "My private PC can, however, connect from my home to my office work PC, however the Quartus Prime Pro installed on that PC forbids any remote operation, thus forcing me to actually do the work by physically being in the office - this is the main problem I seek to solve."
When you say it forbids remote operation, what is actually happening that is not working as expected?
- TSS35 years ago
It's a Pro and I have node-locked license installed.
I can open the Quartus from home (remote), but then I get error messages regarding licensing and database loading.
When I open the Quartus at office, of course it's w/o said error messages.
From home, I can do trivial Quartus work - browse some files, review settings, etc.. but no matter wherever I opened the Quartus (at work or from home) - compilation aborts after ~1minute, again - due to licensing issues.
I'm working with VPN.
All other apps on my machine can be operated by remote, except Quartus and another one, that also runs on a node-locked license.
