openvino : what is the reason for this , how to resolve?
after running this script , the following errors are obtained
script: ./demo_squeezenet_download_convert_run.sh
ERRORS:
################|| Downloading models ||################
========== Retrieving /root/openvino_models/models/public/squeezenet1.1/squeezenet1.1.prototxt from the cache
========== Downloading /root/openvino_models/models/public/squeezenet1.1/squeezenet1.1.caffemodel
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 852, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/usr/lib/python3/dist-packages/urllib3/util/ssl_.py", line 332, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.6/ssl.py", line 407, in wrap_socket
_context=self, _session=session)
File "/usr/lib/python3.6/ssl.py", line 817, in __init__
self.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 1077, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 689, in do_handshake
ConnectionResetError: [Errno 104] Connection reset by peer
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.6/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3/dist-packages/six.py", line 692, in reraise
raise value.with_traceback(tb)
chunked=chunked)
conn.connect()
self.do_handshake()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/downloader/downloader.py", line 65, in try_download
chunk_iterable = start_download()
File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/downloader/downloader.py", line 244, in <lambda>
lambda: model_file.source.start_download(session, CHUNK_SIZE)):
File "/opt/intel/openvino_2019.3.376/deployment_tools/open_model_zoo/tools/downloader/common.py", line 172, in start_download
response = session.get(self.url, stream=True, timeout=DOWNLOAD_TIMEOUT)
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
########## Error: Download failed
################|| Post-processing ||################
FAILED:
squeezenet1.1
Error on or near line 159; exiting with status 1
- JohnT_Altera
May I know if you follow the guide in https://docs.openvinotoolkit.org/latest/_tools_downloader_README.html to install all the prerequisite dependencies file?
- Titanameda
Thank you for your reply
No , I have not ,
so now I have installed the necessary requirements , as below
1./opt/intel/openvino/deployment_tools/open_model_zoo/tools/downloader# python3 -mpip install --user -r ./requirements.in
but the error persists ,i have followed this guide
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux_fpga.html
2. Isn't there another approach to program the Mustang? apart from USB blaster , via PCIe something like opencl?
3. any guides on how to connect the to the host machine ,like power, the harware connections ?
- JohnT_Altera
The error looks like you are not able to download the model from Github. Could you check your internet connection?
Currently you have not move towards running it on FPGA yet as it is more towards the package downloading and setup.
- Titanameda
hello ,
so I am referring this document and in page 20 , a driver has to be installed , that particular driver is not present , so where can i find the driver , from intel? or any other alternative method.
https://files.icp-deutschland.de/produkte/KC001777/web/Mustang-F100-A10_UMN_v1.02-manual-20190212.pdf
Thank you
- JohnT_Altera
For the PCIe driver then please refer to https://docs.openvinotoolkit.org/latest/_docs_install_guides_VisionAcceleratorFPGA_Configure_2019R3.html which you will need to download the fpga_support_files.tgz which contain the BSP and driver. Please follow the step provide to install the card.
- Titanameda
Question No:1:
- https://docs.openvinotoolkit.org/latest/_docs_install_guides_VisionAcceleratorFPGA_Configure_2019R1.html , following this guide, so after step 10 , I get the following errors:
./install_openvino_fpga_dependencies.sh
Getting OpenVINO Information
Would you like to setup an FPGA? Select an option below.
Select (1) for None, (2) Intel® Arria® 10 GX FPGA Development Kit, (3) for Intel® Vision Accelerator Design with Intel® Arria® 10 FPGA (IEI Mustang-F100-A10):
1) none
3) Intel® Vision Accelerator Design with Intel® Arria® 10 FPGA (IEI Mustang-F100-A10)
#? 3
Selected:
The NEO OpenCL GPU driver is required for using the GPU with OpenVINO. Would you like to install it?
Please select (y/n)
y
Do you want to setup a Movidius Neural Compute Stick?
Please select (y/n)
y
Do you want to setup an Intel® Vision Accelerator Design with Intel® Movidius™ VPUs card?
Please select (y/n)
y
Install NEO OCL
Intel OpenCL graphics driver installer
Looking for previously installed user-mode driver...
Found intel-opencl installed, uninstalling...
(Reading database ... 284686 files and directories currently installed.)
Removing intel-opencl (19.32.13826) ...
Purging configuration files for intel-opencl (19.32.13826) ...
dpkg: warning: while removing intel-opencl, directory '/etc/OpenCL/vendors' not empty so not removed
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Found intel-ocloc installed, uninstalling...
(Reading database ... 284681 files and directories currently installed.)
Removing intel-ocloc (19.32.13826) ...
Purging configuration files for intel-ocloc (19.32.13826) ...
dpkg: warning: while removing intel-ocloc, directory '/usr/local/bin' not empty so not removed
Found intel-gmmlib installed, uninstalling...
(Reading database ... 284679 files and directories currently installed.)
Removing intel-gmmlib (19.2.3) ...
Purging configuration files for intel-gmmlib (19.2.3) ...
Found intel-igc-core installed, uninstalling...
dpkg: dependency problems prevent removal of intel-igc-core:
intel-igc-opencl depends on intel-igc-core (= 1.0.10-2407).
dpkg: error processing package intel-igc-core (--purge):
dependency problems - not removing
Errors were encountered while processing:
intel-igc-core
ERROR: unable to remove intel-igc-core
please resolve it manually and try to launch the script again.
usermod: user '' does not exist
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package libboost-program-options1.58.0
E: Couldn't find any package by glob 'libboost-program-options1.58.0'
E: Couldn't find any package by regex 'libboost-program-options1.58.0'
E: Unable to locate package libboost-thread1.58.0
E: Couldn't find any package by glob 'libboost-thread1.58.0'
E: Couldn't find any package by regex 'libboost-thread1.58.0'
E: Unable to locate package libboost-filesystem1.58.0
E: Couldn't find any package by glob 'libboost-filesystem1.58.0'
E: Couldn't find any package by regex 'libboost-filesystem1.58.0'
E: Unable to locate package libjson-c2
./install_openvino_fpga_dependencies.sh: line 371: /deployment_tools/inference_engine/external/hddl/generate_udev_rules.sh: No such file or directory
sed: can't read /etc/udev/rules.d/98-hddlbsl.rules: No such file or directory
[Error] Can't find path to HDDL-R drivers. Skipping HDDL-R setup. (===========ERROR================= )
libelf-dev is already the newest version (0.170-0.4ubuntu0.1).
The following packages were automatically installed and are no longer required:
libavdevice57 libavfilter6 libavresample3 libc6-dev:i386 linux-libc-dev:i386 x11proto-dri2-dev x11proto-gl-dev
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 122 not upgraded.
Installed HDDL-F BSP Files: (hddlf/2019.r1/a10_1150_sg1/ to /opt/altera/aocl-pro-rte/aclrte-linux64/board)
[Error] You have multiple versions of Quartus installed! Please choose one to fix.
Which version of Quartus do you want to fix?
Please select (y/n)
y
[Info] Warning: multipe multiple Quartus instances found!
Size of array: 2
/home/tata/intelFPGA/18.1/qprogrammer /root/intelFPGA/18.1/qprogrammer
1) /home/tata/intelFPGA/18.1/qprogrammer
2) /root/intelFPGA/18.1/qprogrammer
#? 2
You selected: /root/intelFPGA/18.1/qprogrammer
Installing aocl flash fix to: /root/intelFPGA/18.1/qprogrammer/linux64
[Info] Success! OpenVINO FPGA dependencies installed.
Question No 2:
The next step involves flashing with the USB flasher ,
1.Cant we achieve this without the USB flashing ?
2.What about Opencl methodology of sending .aocx files to fpga, or any other methodologies.
Thank You
- JohnT_Altera
Question No:1:
The error that you observed is not related to FPGA. So you should be able move forward with your testing.
Question No 2:
You only need to do it the 1st time if you are it is preloaded with the image with the same OpenVINO version.
If you are just want to run different topology then you can use "aocl program ***.aocx" which will update the FPGA topology. If the preloaded image is using different OpenVINO version then you will need to use USB Blaster to flash it before you are able to program it.
- Titanameda
https://files.icp-deutschland.de/produkte/KC001777/web/Mustang-F100-A10_UMN_v1.02-manual-20190212.pdf,
pg:20 and 21
In this guide , the flashing is not done , an alternate method is provided , does this work?
- JohnT_Altera
Yes. it will work if you are able to program it. If you see issue on programming it then you will need to flash the FPGA.
- Titanameda
hi ,
Following this guide to install FPGA support files
messages observed :
aocl install
Do you want to install /opt/intelFPGA_pro/18.1/hld/board/a10_ref? [y/n] y
aocl install: Adding the board package /opt/intelFPGA_pro/18.1/hld/board/a10_ref to the list of installed pckages
aocl install: Setting up FCD
aocl install: Running install from /opt/intelFPGA_pro/18.1/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/4.15.0-70-generic/build
Using kernel source files from /lib/modules/4.15.0-70-generic/build
Building driver for BSP with name a10_ref
make: Entering directory '/usr/src/linux-headers-4.15.0-70-generic'
CC [M] /tmp/opencl_driver_axJYyF/aclpci_queue.o
CC [M] /tmp/opencl_driver_axJYyF/aclpci.o
CC [M] /tmp/opencl_driver_axJYyF/aclpci_fileio.o
CC [M] /tmp/opencl_driver_axJYyF/aclpci_dma.o
CC [M] /tmp/opencl_driver_axJYyF/aclpci_pr.o
CC [M] /tmp/opencl_driver_axJYyF/aclpci_cmd.o
LD [M] /tmp/opencl_driver_axJYyF/aclpci_a10_ref_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/opencl_driver_axJYyF/aclpci_a10_ref_drv.mod.o
LD [M] /tmp/opencl_driver_axJYyF/aclpci_a10_ref_drv.ko
make: Leaving directory '/usr/src/linux-headers-4.15.0-70-generic'
aocl diagnose
Warning:
No devices attached for package:
Vendor: Intel(R) Corporation
Found no active device installed on the host machine.
Please make sure to:
1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct board package.
2. Install the driver from the selected board package.
3. Properly install the device in the host machine.
4. Configure the device with a supported OpenCL design.
5. Reboot the machine if the PCI Express link failed.
DIAGNOSTIC_FAILED
How to resolve this
