11 years agoOpenCore Plus Hardware Evaluation feature is turned on, but no .sof file is produced.
Hello!
What could be the cause if Quartus 13.1 ( Web edition ) reports the following warnings during compilation and does not produce any .sof file: Warning (12188): OpenCore Plus Hardware Evaluation feature is turned on for the following cores Warning (12190): "SDI Interface (SD, HD)" will use the OpenCore Plus Hardware Evaluation feature Warning (265072): Messages from megafunction that supports OpenCore Plus feature Warning (265073): Messages from megafunction that supports OpenCore Plus feature IP-AUDIO_EMBED Warning (265074): The Audio Embed MegaCore function will be disabled after time-out is reached Warning (265073): Messages from megafunction that supports OpenCore Plus feature IP-AUDIO_EXTRACT Warning (265074): The Audio Extract MegaCore function will be disabled after time-out is reached Warning (265069): Megafunction that supports OpenCore Plus feature will stop functioning in 1 hour after device is programmed Compilation report also says, that "OpenCore Plus Hardware Evaluation feature is turned on for all cores in the design." But why no .sof file is produced?
