12 years agoHi all
Thanks for your help. I am actually using the board remotely. I have confirmed that the board that I am accessing is a Nallatech board. I thought that I was using the bitware board since the device code obtained as a consequence of lspci command was e385, which the getting started documentation on OpenCL indicates to be a Bitware device code. The output of lspci is as follows: $ lspci | grep Altera 03:00.0 Unassigned class [ff00]: Altera Corporation Device e385 (rev 01) How should I interpret the result of the above lspci command ?
